LTM4611 pdf,datasheet
消耗积分:5 | 格式:rar | 大小:132 | 2010-07-17
分享资料个
Ultralow VIN, 15A DC/DC μModule Regulator
The LTM4611 is a high density 15A output, switch mode
DC/DC buck converter power supply capable of operating
from very low voltage input supplies. Included in the package
are the buck switching controller, power FETs, inductor
and loop-compensation components. The LTM4611
delivers up to 15A continuous current at high efficiency
from an input voltage of 1.5VIN up to 5.5VIN. The output
voltage is set between 0.8V and 5V by a resistor. Only a
few input and output capacitors are needed.
评论(0)
发评论
下载排行榜
