SN54HCT645, SN74HCT645,pdf(OCT
消耗积分:2 | 格式:rar | 大小:471 | 2010-07-24
久醉不醒
分享资料个
These octal bus transceivers are designed for asynchronous two-way communication between data buses. These devices transmit data from the A bus to the B bus or from the B bus to the A bus, depending upon the level at the direction-control (DIR) input. The output-enable (OE)\ input can be used to disable the device so the buses are effectively isolated.
评论(0)
发评论
下载排行榜
