SN54HC174, SN74HC174,pdf(EHX D
消耗积分:3 | 格式:rar | 大小:821 | 2010-07-29
王银喜
分享资料个
These positive-edge-triggered D-type flip-flops have a direct clear (CLR)\ input.
Information at the data (D) inputs meeting the setup time requirements is transferred to the outputs on the positive-going edge of the clock (CLK) pulse. Clock triggering occurs at a particular voltage level and is not directly related to the transition time of the positive-going edge of CLK. When CLK is at either the high or low level, the D input has no effect at the output.
评论(0)
发评论
下载排行榜
