1.1 S3C6410 Pin Description.6
1.2 Pin Power Domain.14
1.3 Booting Option..15
1.4 Feature of the IROM Boot mode16
1.5 Recommend Operating Conditions.17
1.6 Difference of S3C6410 and S3C6400..18
2. MEMORY MAP.20
2.1 Maximum Address range of the Memory Port0...20
2.2 Maximum Address range of the Memory Port1...20
3. Syscon21
3.1 Power.21
3.1.1 Power On Sequence21
3.1.2 Power Off Sequence24
3.1.3 Power Scheme Diagram25
3.1.4 Circuit Guide for DVS Scheme26
3.2 Clock..27
3.2.1 PLL.27
3.3 Reset.29
3.3.1 HardWare Reset..29
4. MEMORY SUBSYSTEM..30
5. DRAM Controller31
5.1 Memory Port0...31
5.2 Memory Port1...31
5.3 DRAM Initialize Sequence33
5.4 PCB LAYOUT GUIDELINES FOR DDR...36
6. SROM Controller39
6.1 Address Connection...39
6.2 SRAM/ROM Interface Examples39
7. OneNAND Controller...41
7.1 Overview.41
7.2 Signal Description..41
7.3 Circuit Diagram Example..41
7.4 Caution..42
8. NAND Flash.43
8.1 Interface for Multi Chip Select NAND...43
9. CF Controller44
9.1 CF Interface.44
9.2 Cautions..45
9.3 ATA 2 Slot operation guide46
10. GPIO.48
11. DMA Controller54
12. VECTORED INTERRUPT CONTROLLER...55
13. SECURITY SUB-SYSTEM...56
14. DISPLAY CONTROLLER...57
15. POST PROCESSOR.61
16. TV SCALER62
17. TV ENCODER.63
18. GRAPHICS 2D65
19. IMAGE ROTATOR66
20. CAMERA INTERFACE...67
20.1 CAMIF INPUT..67
20.2 Signal Description67
21. MULTI-FORMAT VIDEO CODEC...69
22. JPEG CODEC70
23. MODEM INTERFACE71
23.1 Pin Description71
23.2 Pin Connection Example..72
23.3 Caution72
24. HOST INTERFACE73
25. USB Host74
25.1 Power Domain.74
25.2 Circuit Diagram Example..74
25.3 USB Host connection...74
25.4 Caution74
26. USB 2.0 HS OTG...75
26.1 Power Domain.75
26.2 Circuit Diagram Example..75
26.3 USB PLL Specification.77
26.4 USB SIGNAL ROUTING..77
27. SD/MMC HOST CONTROLLER.79
28. MIPI HSI INTERFACE CONTROLLER...82
29. SPI..83
30. IIC-BUS INTERFACE.84
30.1 Pin Description84
30.2 Equation of the pull-up resistor value...84
31. UART..85
32. PWM TIMER..86
33. RTC87
34. WATCHDOG TIMER..88
35. AC97 CONTROLLER.89
35.1 AC97 Signal Description...89
35.2 Audio Ports..89
35.3 Signal Description89
36. IIS BUS CONTROLLER.90
36.1 Signal Description90
36.2 Audio Port90
36.3 External Clock Source..90
36.4 Connection Example90
37. PCM BUS CONTROLLER.92
37.1 Signal Description92
37.2. Audio Port...92
37.3 External Clock Source..92
37.4 Connection Example93
38. IRDA CONTROLLER.94
39. ADC&TOUCH SCREEN INTERFACE95
40. KEYPAD INTERFACE...96
41. IIS MULTI AUDIO INTERFACE..97
41.1 Signal Description97
41.2 Audio Ports..97
41.3 External Clock Source..98
41.4 Connection Example98
42. GRAPHIC 3D.99
