TCA4311,pdf(Hot Swappable 2-Wi
消耗积分:3 | 格式:rar | 大小:526 | 2010-08-08
贾熹
分享资料个
特性
  • Operating Power-Supply Voltage Range of 2.7-V to 5.5-V
  • Supports Bidirectional Data Transfer of I2C Bus Signals
  • SDA and SCL Lines Are Buffered Which Increases Fanout
  • 1-V Precharge on All SDA and SCL Lines Prevents
    Corruption During Live Board Insertion and Removal From Backplane
  • SDA and SCL Input Lines Are Isolated From Outputs
  • Accommodates Standard Mode and Fast Mode I2C Devices
  • Applications Include Hot Board Insertion and Bus Extension
  • Low ICC Chip Disable of <1 µA
  • READY Open-Drain Output
  • Supports Clock Stretching, Arbitration, and Synchronization
  • Powered-Off High-Impedance I2C Pins
  • Open-Drain I2C Pins
  • Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II
  • ESD Protection Exceeds JESD 22
    • 8000-V Human-Body Model (A114-A)
    • 200-V Machine Model (A115-A)
    • 1000-V Charged-Device Model (C101)
评论(0)
发评论
下载排行榜
