SN75150,pdf(Dual Line Driver)
消耗积分:3 | 格式:rar | 大小:469 | 2010-09-02
分享资料个
The SN75150 is a monolithic dual line driver designed to satisfy the requirements of the standard interface between data-terminal equipment and data-communication equipment as defined by TIA/EIA-232-F. A rate of 20 kbits/s can be transmitted with a full 2500-pF load. Other applications are in data-transmission systems using relatively short single lines, in level translators, and for driving MOS devices. The logic input is compatible with most TTL families. Operation is from 12-V and -12-V power supplies.
The SN75150 is characterized for operation from 0°C to 70°C.
评论(0)
发评论
下载排行榜
