OPA2333,pdf(1.8V, microPOWER C
消耗积分:5 | 格式:rar | 大小:1007 | 2010-09-15
分享资料个
The OPA333 series of CMOS operational amplifiers
uses a proprietary auto-calibration technique to
simultaneously provide very low offset voltage (10 μ V
max) and near-zero drift over time and temperature.
These miniature, high-precision, low quiescent
current amplifiers offer high-impedance inputs that
have a common-mode range 100mV beyond the rails
and rail-to-rail output that swings within 50mV of the
rails. Single or dual supplies as low as +1.8V ( ± 0.9V)
and up to +5.5V ( ± 2.75V) may be used. They are
optimized for low-voltage, single-supply operation.
The OPA333 family offers excellent CMRR without
the crossover associated with traditional
complementary input stages. This design results in
superior performance for driving analog-to-digital
converters (ADCs) without degradation of differential
linearity.
The OPA333 (single version) is available in the
SC70-5, SOT23-5, and SO-8 packages. The
OPA2333 (dual version) is offered in DFN-8 (3mm ×
3mm), MSOP-8, and SO-8 packages. All versions
are specified for operation from – 40 ° C to +125 ° C.
评论(0)
发评论
下载排行榜
