LM2900,LM3900,pdf(Quadruple Op
消耗积分:3 | 格式:rar | 大小:485 | 2010-09-17
韩刚龙
分享资料个
These devices consist of four independent, high-gain frequency-compensated Norton operational amplifiers that were designed specifically to operate from a single supply over a wide range of voltages. Operation from split supplies is also possible. The low supply current drain is essentially independent of the magnitude of the supply voltage. These devices provide wide band- width and large output voltage swing.
The LM2900 is characterized for operation from -40°C to 85°C, and the LM3900 is characterized for operation from 0°C to 70°C.
评论(0)
发评论
下载排行榜
