THS4508,pdf(Wideband Low Noise
消耗积分:5 | 格式:rar | 大小:1052 | 2010-09-18
分享资料个
特性
  • Fully Differential Architecture
  • Common-Mode Input Range Includes the
    Negative Rail
  • Minimum Gain of 2 V/V (6 dB)
  • Bandwidth: 2 GHz
  • Slew Rate: 6400 V/µs
  • 1% Settling Time: 2 ns
  • HD2: -72 dBc at 100 MHz
  • HD3: -79 dBc at 100 MHz
  • OIP2: 78 dBm at 70 MHz
  • OIP3: 42 dBm at 70 MHz
  • Input Voltage Noise: 2.3 nV/√Hz (f > 10 MHz)
  • Noise Figure: 19.2 dB (G = 10 dB)
  • Output Common-Mode Control
  • 5-V Power Supply Current: 39.2 mA
  • Power-Down Capability: 0.65 mA
  • APPLICATIONS
    • 5-V Data-Acquisition Systems
    • High Linearity ADC Amplifier
    • Wireless Communication
    • Medical Imaging
评论(0)
发评论
下载排行榜
