ISO120,ISO121,pdf(Precision Lo
消耗积分:2 | 格式:rar | 大小:187 | 2010-09-25
分享资料个
The ISO120 and ISO121 are precision isolation ampli-
fiers incorporating a novel duty cycle modulation-
demodulation technique. The signal is transmitted
digitally across a 2pF differential capacitive barrier.
With digital modulation the barrier characteristics do
not affect signal integrity, which results in excellent
reliability and good high frequency transient immu-
nity across the barrier. Both the amplifier and barrier
capacitors are housed in a hermetic DIP. The ISO120
and ISO121 differ only in package size and isolation
voltage rating.
These amplifiers are easy to use. No external compo-
nents are required for 60kHz bandwidth. With the
addition of two external capacitors, precision specifi-
cations of 0.01% max nonlinearity and 150µV/°C max
VOS drift are guaranteed with 6kHz bandwidth. A
power supply range of ±4.5V to ±18V and low quies-
cent current make these amplifiers ideal for a wide
range of applications.
评论(0)
发评论
下载排行榜
