BQ2010,pdf(Gas Gauge IC)
消耗积分:5 | 格式:rar | 大小:463 | 2010-11-05
王璐
分享资料个
The bq2010 Gas Gauge IC is intended for battery-pack or in-system installation to maintain an accurate record of a battery’s available charge. The IC monitors a voltage drop across a sense resistor connected in series between the negative battery terminal and ground to determine charge and discharge activity of the battery.
NiMH and NiCd battery self-discharge is estimated based on an internal timer and temperature sensor. Compensations for battery temperature and rate of charge or discharge are applied to the charge, discharge, and self-discharge calculations to provide available charge information across a wide range of operating conditions. Battery capacity is automatically recalibrated, or "learned," in the course of a discharge cycle from full to empty.
评论(0)
发评论
下载排行榜
