PT4227,pdf(10 Watt Low Profile
消耗积分:5 | 格式:rar | 大小:186 | 2010-11-12
郑成枝
分享资料个
The PT4220 power modules are a series of DC/DC converters housed in an ultra-low profile (8mm) solderable copper case. The series includes a number of preset output voltages ranging from 1.3V up to 12V, all fully approved for Telecom use. They may also be used in many other applications that require input-output isolation over an extended temperature range. The modules are an ideal choice for low-power digital and analog circuits, including DSPs and microcontrollers. The flexibility of input-output isolation also allows the output to be configured for negative voltage operation.
The PT4220 series is made available in both horizontal and vertical pin configurations, including surface mount.
评论(0)
发评论
下载排行榜
