The PT78NR200 series creates negative output voltage from a positive input voltage greater than 9V. These easy-to-use, 3-terminal, Integrated Switching Regulator (ISRs) have maximum output power of 10 to 12 watts and a negative output voltage that is laser trimmed. They also have excellent line and load regulation.
The PT78NR200 requires 100 LFM of airflow at its maximum output current.
