The RT9902 is a complete power supply solution for digital still cameras and other hand-held devices. It integrates a high-efficiency main step-up DC-DC converter, two highefficiency step-down converters, a charge pump, and a linear controller that drives an external P-Channel MOSFET for linear regulator. The RT9902 is targeted for applications that use either two or three AA cells or a single lithiumion battery. The main step-up DC-DC converter accepts inputs from 1.5V to 5.5V and build in 2.6A Internal switch. The two step-down DC-DC converters (CH2, CH3) accept inputs from 1.5V to 5.5V and regulate a resistor adjustable output from 0.8V to 5.5V. Each DC-DC converter has independent shutdown input. The feature of the charge pump is to deliver few current to micro-controller when the system operates in the standby mode. RT9902 includes a linear controller with 0.8V reference voltage. An adjustable operating frequency (up to 1.4MHz) is utilized to get optimum size, cost, and efficiency. RT9902 is available in VQFN-32L 5x5 package.
