MAX5893 pdf datasheet (Dual DA
消耗积分:3 | 格式:rar | 大小:333 | 2008-12-18
李鸿洋
分享资料个
The MAX5893 programmable interpolating, modulating,
500Msps, dual digital-to-analog converter (DAC) offers
superior dynamic performance and is optimized for high-
performance wideband, single-carrier transmit applica-
tions. The device integrates a selectable 2x/4x/8x
nterpolating filter, a digital quadrature modulator, and
dual 12-bit high-speed DACs on a single integrated cir-
cuit. At 30MHz output frequency and 500Msps update
rate, the in-band SFDR is 84dBc while consuming 1.1W.
The device also delivers 72dB ACLR for single-carrier
WCDMA at a 61.44MHz output frequency.
The selectable interpolating filters allow lower input data
rates while taking advantage of the high DAC update
rates. These linear-phase interpolation filters ease
reconstruction filter requirements and enhance the
passband dynamic performance. Individual offset and
gain programmability allow the user to calibrate out local
oscillator (LO) feedthrough and sideband suppression
errors generated by analog quadrature modulators.
评论(0)
发评论
下载排行榜
