ISO124 Precision Lowest Cost I
消耗积分:5 | 格式:rar | 大小:333 | 2008-12-18
分享资料个
The ISO124 is a precision isolation amplifier incorporating
a novel duty cycle modulation-demodulation
technique. The signal is transmitted digitally across
a 2pF differential capacitive barrier. With digital modulation
the barrier characteristics do not affect signal
integrity, resulting in excellent reliability and good high
frequency transient immunity across the barrier. Both
barrier capacitors are imbedded in the plastic body of
the package.
The ISO124 is easy to use. No external components
are required for operation. The key specifications are
0.010% max nonlinearity, 50kHz signal bandwidth,
and 200mV/°C VOS drift. A power supply range of
±4.5V to ±18V and quiescent currents of ±5.0mA on
VS1 and ±5.5mA on VS2 make these amplifiers ideal
for a wide range of applications.
The ISO124 is available in 16-pin plastic DIP and 28-
lead plastic surface mount packages.
评论(0)
发评论
下载排行榜
