HA-2548/883 pdf datasheet(Prec
消耗积分:3 | 格式:rar | 大小:59 | 2008-12-28
刘杰
分享资料个
Features
• This Circuit is Processed in Accordance to MIL-STD-
883 and is Fully Conformant Under the Provisions of
Paragraph 1.2.1.
• High Slew Rate . . . . . . . . . . . . . . . . . . . . . 120V/μs (Typ)
• Low Offset Voltage. . . . . . . . . . . . . . . . . . . . 300μV (Typ)
900μV (Max)
• High Open Loop Gain . . . . . . . . . . . . . . . . . 130dB (Typ)
114dB (Min)
• Gain Bandwidth Product . . . . . . . . . . . . . 150MHz (Typ)
• Low Voltage Noise at 1kHz . . . . . . . . . .8.3nV/√Hz (Typ)
• Minimum Gain Stability . . . . . . . . . . . . . . . . . . .≥ 5 (Typ)
Applications
• High Speed Instrumentation
• Data Acquisition Systems
• Analog Signal Conditioning
• Precision, Wideband Amplifiers
• Pulse/RF Amplifiers
评论(0)
发评论
下载排行榜
