The EL5185 comparator is designed for operation in single supply and dual supply applications with 5V to 12V between VS+ and VS-. For single supplies, the inputs can operate from 0.1V below ground for use in ground-sensing applications. The output side of the comparator can be supplied from a single supply of 2.7V to 5V. The rail-to-rail output swing enables direct connection of the comparator to both CMOS and TTL logic circuits. The latch input of the EL5185 can be used to hold the comparator output value by applying a low logic level to the pin. The EL5185 is available in the 8-pin SO package and is specified for operation over the -40°C to +85°C temperature range. Also available are dual (EL5285), window comparator (EL5287), and quad (EL5485 and EL5486) versions.
