EL5611, EL5811 pdf datasheet (
消耗积分:2 | 格式:rar | 大小:533 | 2009-01-16
李丽
分享资料个
The EL5611 and EL5811 are low power, high voltage rail-torail
input-output amplifiers targeted primarily at VCOM
applications in TFT-LCD displays. The EL5611 contains six
amplifiers, and the EL5811 contains eight amplifiers.
Operating on supplies ranging from 5V to 15V, while
consuming only 2.5mA per amplifier, the EL5611 and
EL5811 have a bandwidth of 60MHz (-3dB). They also
provide common mode input ability beyond the supply rails,
as well as rail-to-rail output capability. This enables these
amplifiers to offer maximum dynamic range at any supply
voltage.
The EL5611 and EL5811 also feature fast slewing and
settling times, as well as a high output drive capability of
65mA (sink and source). In addition to VCOM applications,
these features make these amplifiers ideal for high speed
filtering and signal conditioning application. Other
applications include battery power, portable devices, and
anywhere low power consumption is important.
The EL5611 is available in 8-pin MSOP and 8-pin HMSOP
packages. The EL5811 is available in space-saving 28-pin
HTSSOP packages.These amplifiers operate over a
temperature range of -40°C to +85°C.
评论(0)
发评论
下载排行榜
