EL2480 pdf datasheet (250MHz/3
消耗积分:3 | 格式:rar | 大小:444 | 2009-01-17
362163
分享资料个
The EL2480 is a quad current-feedback operational amplifier
which achieves a -3dB bandwidth of 250MHz at a gain of +1
while consuming only 3mA of supply current per amplifier. It
will operate with dual supplies ranging from ±1.5V to ±6V, or
from single supplies ranging from +3V to +12V. In spite of its
low supply current, the EL2480 can output 55mA while
swinging to ±4V on ±5V supplies. These attributes make the
EL2480 an excellent choice for low power and/or low voltage
cable-driver, HDSL, or RGB applications.
For triple applications with disable, consider the EL2386 (16-
pin triple).
评论(0)
发评论
下载排行榜
