EL2044 pdf datasheet (Gain Sta
消耗积分:5 | 格式:rar | 大小:443 | 2009-01-17
分享资料个
The EL2044 is a high speed, low
power, low cost monolithic operational
amplifier built on Elantec's proprietary
complementary bipolar process. The EL2044 is unity-gain
stable and features a 325V/μs slew rate and 120MHz gainbandwidth
product while requiring only 5.2mA of supply
current.
The power supply operating range of the EL2044 is from
±18V down to as little as ±2V. For single-supply operation,
the EL2044 operates from 36V down to as little as 2.5V. The
excellent power supply operating range of the EL2044
makes it an obvious choice for applications on a single +5V
supply.
The EL2044 also features an extremely wide output voltage
swing of ±13.6V with VS = ±15V and RL = 1kΩ. At ±5V,
output voltage swing is a wide ±3.8V with RL = 500Ω and
±3.2V with RL = 150Ω. Furthermore, for single-supply
operation at +5V, output voltage swing is an excellent 0.3V
to 3.8V with RL = 500Ω.
评论(0)
发评论
下载排行榜
