MAX14978,pdf (SuperSpeed USB Passive)
消耗积分:0 | 格式:pdf | 大小:322 KB | 2011-05-29
dplion
分享资料个
The MAX14978 high-performance, passive analog switch is ideal for switching Hi-Speed USB and SuperSpeed USB data between one source and two loads, or vice versa. The device can be used in desktop and notebook applications where SuperSpeed USB ports are in limited supply. The device consists of two sets of analog switches with one set used for USB low-speed, full-speed, and Hi-Speed signals and the second set used for USB SuperSpeed.The device operates from a single +3.3V supply.
The device features low insertion loss for all speeds. It has  Q6kV Human Body Model (HBM) ESD protection on all I/O pins. In addition, the low/full/Hi-Speed COM_ports have ESD protection to Q15kV HBM and Q8kV IEC 61000-4-2 contact.
The device is available in a small, 3.5mm x 9.0mm,42-pin TQFN package and is specified over the extend-ed -40NC to +85NC temperature range.
Applications
Desktop PCs
Laptop PCs
Industrial USB Switching
评论(0)
发评论
下载排行榜
