The MAX5974_ provide control for wide-input-voltage,active-clamped, current-mode PWM, forward convertersin Power-over-Ethernet (PoE) powered device (PD) applications.
The MAX5974A/MAX5974C are well-suited foruniversal or telecom input range, while the MAX5974B/MAX5974D also accommodate low input voltage downto 10.5V.
