MAX9209,MAX9213英文数据资料
消耗积分:0 | 格式:pdf | 大小:502 KB | 2012-04-20
分享资料个
The MAX9209/MAX9213 serialize 21 bits of LVTTL/LVCMOS parallel input data to three LVDS outputs. Aparallel rate clock on a fourth LVDS output providestiming for deserialization.
The MAX9209/MAX9213 feature programmable DC balance,which allows isolation between the serializer anddeserializer using AC-coupling. The DC balance circuitson each channel code the data, limiting the imbalanceof transmitted ones and zeros to a defined range. Thecompanion MAX9210/MAX9214 deserializers decodethe data. When DC balance is not programmed, theserializers are compatible with non-DC-balanced, 21-bitserializers such as the DS90CR215 and DS90CR217.
评论(0)
发评论
下载排行榜
