The MAX14778 dual 4:1 analog multiplexer supportsanalog signals up to Q25V with a single 3.0 to 5.5Vsupply. Each multiplexer has separate control inputs toallow independent switching, making the device ideal formultiplexing different communications signals with thesame connector pins. Extended ESD protection of Q6kV(Human Body Model) enable direct interfacing to cablesand connectors.
