The DeCAPitator is designed to reduce the number of bulk
capacitors required at the output of a switching DC-DC
converter powering a microprocessor in a portable
computer. It contains two high-speed linear regulators which
are only active if the processor core voltage is disturbed by a
fast moving load transient. Figure 1 shows the HIP6200 in its
typical application. Refer to the HIP6200 data sheet [1] for
detailed specifications.
