MAX4073F,MAX4073H,MAX4073T数据资料
消耗积分:0 | 格式:pdf | 大小:440 KB | 2012-09-27
分享资料个
The MAX4073 low-cost, high-side current-sense amplifierfeatures a voltage output that eliminates the needfor gain-setting resistors making it ideal for cell phones,notebook computers, PDAs, and other systems wherecurrent monitoring is crucial. High-side current monitoringdoes not interfere with the ground path of thebattery charger making the MAX4073 particularly usefulin battery-powered systems. The input common-moderange of +2V to +28V is independent of the supply voltage.The MAX4073’s wide 1.8MHz bandwidth makes itsuitable for use inside battery-charger control loops.The combination of three gain versions and a selectableexternal-sense resistor sets the full-scale currentreading. The MAX4073 offers a high level of integration,resulting in a simple and compact current-sensesolution.
评论(0)
发评论
下载排行榜
