8-Bit μP Compatible A/D Converters with 8-Channel Multiplexer ADC0808
消耗积分:1 | 格式:pdf | 大小:370KB | 2014-08-27
liu12
分享资料个
The ADC0808, ADC0809 data acquisition component is a monolithic CMOS device with an 8-bit analog-to-digital converter, 8-channel multiplexer and microprocessor compatible control logic。 The 8-bit A/D converter uses successive approximation as the conversion technique。The converter features a high impedance chopper stabilized comparator, a 256R voltage divider with analog switch tree and a successive approximation register。 The 8-channel multiplexer can directly access any of 8-single-ended analog signals。
评论(0)
发评论
下载排行榜
