SSM2301,pdf datasheet (Class-D
消耗积分:3 | 格式:rar | 大小:500 | 2009-08-24
33391
分享资料个
The SSM2301 is a fully integrated, high efficiency, Class-D audio amplifier designed to maximize performance for mobile phone applications. The application circuit requires a minimum of external components and operates from a single 2.5 V to 5.0 V supply. It is capable of delivering 1.4 W of continuous output power with less than 1% THD + N driving an 8 Ω load from a 5.0 V supply.
The SSM2301 features a high efficiency, low noise modulation scheme that does not require external LC output filters. The modu-lation provides high efficiency even at low output power.
评论(0)
发评论
下载排行榜
