The AMC7169 is a two terminal LED protector, and low dropout voltage rated for 500mA bypass current. Low operation current at monitoring mode and high bypass current capability at triggered mode. Build-in reverse diode for bypass reversed supply voltage. The AMC7169 is designed for parallel connect with power LED. It bypass LED driving current when LED at open circuit condition. It also bypass LED driving current at reverse connected driving current to LED.
