ZD860,pdf datasheet (1.5A High
消耗积分:3 | 格式:rar | 大小:433 | 2009-08-27
分享资料个
The ZD860 is a constant off-time, high power LED driver IC
that is capable of driving up to 1.5A of output current. It operates
from an input voltage range of 4V to 40V (AC or DC)
and generates a regulated programmable constant output
current for high brightness power LEDs. The integrated
power switch reduces component count by eliminating the
need for an external power switch. Thermal and overvoltage
circuitry protects the power transistors from excessive
power dissipation.
The ZD860 is available in a thermally enhanced 16-pin exposed
TSSOP green package.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
