AD8655/AD8656,pdf datasheet (P
消耗积分:5 | 格式:rar | 大小:323 | 2009-08-28
分享资料个
The AD8655/AD8656 are the industry’s lowest noise, precision CMOS amplifiers. They leverage the Analog Devices DigiTrim® technology to achieve high dc accuracy.
The high precision performance of the AD8655/AD8656 improves the resolution and dynamic range in low voltage applications. Audio applications, such as microphone pre-amps and audio mixing consoles, benefit from the low noise, low distortion, and high output current capability of the AD8655/ AD8656 to reduce system level noise performance and maintain audio fidelity. The high precision and rail-to-rail input and output of the AD8655/AD8656 benefit data acquisition, process controls, and PLL filter applications.
The AD8655/AD8656 provide low noise (2.7 nV/√Hz @ 10 kHz), low THD + N (0.0007%), and high precision performance (250 μV max over VCM) to low voltage applications. The ability to swing rail-to-rail at the input and output enables designers to buffer analog-to-digital converters (ADCs) and other wide dynamic range devices in single-supply systems.
评论(0)
发评论
下载排行榜
