tip127 pdf datasheet
消耗积分:10 | 格式:rar | 大小:333 | 2008-07-08
分享资料个
TIP120
TIP121
TIP122
TIP125
TIP126
TIP127
NPN
PNP
Plastic Medium-Power
Complementary Silicon Transistors
. . . designed for general–purpose amplifier and low–speed
switching applications.
• High DC Current Gain —
hFE = 2500 (Typ) @ IC
= 4.0 Adc
• Collector–Emitter Sustaining Voltage — @ 100 mAdc
VCEO(sus) = 60 Vdc (Min) — TIP120, TIP125
= 80 Vdc (Min) — TIP121, TIP126
= 100 Vdc (Min) — TIP122, TIP127
• Low Collector–Emitter Saturation Voltage —
VCE(sat) = 2.0 Vdc (Max) @ IC = 3.0 Adc
= 4.0 Vdc (Max) @ IC = 5.0 Adc
• Monolithic Construction with Built–In Base–Emitter Shunt Resistors
• TO–220AB Compact Package
评论(0)
发评论
下载排行榜
