ADG3304 ,pdf datasheet (Bidire
消耗积分:3 | 格式:rar | 大小:555 | 2009-09-25
分享资料个
The ADG3304 is a bidirectional logic level translator that con-tains four bidirectional channels. It can be used in multivoltage digital system applications, such as data transfer, between a low voltage digital signal processing controller and a higher voltage device using SPI and MICROWIRE interfaces. The internal architecture allows the device to perform bidirectional logic level translation without an additional signal to set the direction in which the translation takes place.
评论(0)
发评论
下载排行榜
