ADG3242,pdf datasheet (2.5 V/3
消耗积分:2 | 格式:rar | 大小:522 | 2009-09-25
分享资料个
The ADG3242 is a 2.5 V or 3.3 V, 2-bit, 2-port, common control digital switch. It is designed on a low voltage CMOS process, and provides low power dissipation, yet gives high switching speed and very low on resistance. This allows the inputs to be connected to the outputs without additional propagation delay or generating additional ground bounce noise.
评论(0)
发评论
下载排行榜
