LM5030,pdf datasheet (100V Pus
消耗积分:3 | 格式:rar | 大小:559 | 2009-09-29
王兰
分享资料个
The LM5030 High Voltage PWM controller contains all of the
features needed to implement Push-Pull and Bridge topologies,
using current-mode control in a small 10 pin package.
This device provides two alternating gate driver outputs. The
LM5030 includes a high-voltage start-up regulator that operates
over a wide input range of 14V to 100V. Additional
features include: error amplifier, precision reference, dual
mode current limit, slope compensation, softstart, sync capability
and thermal shutdown. This high speed IC has total
propagation delays less than 100ns and a 1MHz capable
single resistor adjustable oscillator.
评论(0)
发评论
下载排行榜
