LM7332,pdf datasheet (30V, Wid
消耗积分:2 | 格式:rar | 大小:558 | 2009-10-07
刘高
分享资料个
The LM7332 is a dual rail-to-rail input and output amplifier with
a wide operating temperature range (−40°C to +125°C) which
meets the needs of automotive, industrial and power supply
applications. The LM7332 has the output current of 100 mA
which is higher than that of most monolithic op amps. Circuit
designs with high output current requirements often need to
use discrete transistors because many op amps have low
current output. The LM7332 has enough current output to
drive many loads directly, saving the cost and space of the
discrete transistors.
评论(0)
发评论
下载排行榜
