LMV641,pdf datasheet (10 MHz,
消耗积分:3 | 格式:rar | 大小:558 | 2009-10-08
分享资料个
The LMV641 is a low power, wide bandwidth operational amplifier
with an extended power supply voltage range of 2.7V
to 12V.
It features 10 MHz of gain bandwidth product with unity gain
stability on a typical supply current of 138 μA. Other key specifications
are a PSRR of 105 dB, CMRR of 120 dB, VOS of
500 μV, input referred voltage noise of 14 nV/ , and a THD
of 0.002%. This amplifier has a rail-to-rail output stage, and a
common mode input voltage which includes the negative supply.
评论(0)
发评论
下载排行榜
