LM4819,pdf datasheet (350mW Au
消耗积分:5 | 格式:rar | 大小:551 | 2009-10-09
李艳
分享资料个
The LM4819 is a mono bridged power amplifier that is capable
of delivering 350mWRMS output power into a 16W load
or 300mWRMS output power into an 8W load with 10%
THD+N from a 5V power supply.
The LM4819 Boomer audio power amplifier is designed
specifically to provide high quality output power and minimize
PCB area with surface mount packaging and a minimal
amount of external components. Since the LM4819 does not
require output coupling capacitors, bootstrap capacitors or
snubber networks, it is optimally suited for low-power portable
applications.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
