ADC081S051,pdf datasheet (Sing
消耗积分:2 | 格式:rar | 大小:556 | 2009-10-12
张艳
分享资料个
The ADC081S051 is a low-power, single channel CMOS 8-
bit analog-to-digital converter with a high-speed serial interface.
Unlike the conventional practice of specifying performance
at a single sample rate only, the ADC081S051 is fully
specified over a sample rate range of 200 ksps to 500 ksps.
The converter is based on a successive-approximation register
architecture with an internal track-and-hold circuit.
The output serial data is straight binary, and is compatible with
several standards, such as SPI™, QSPI™, MICROWIRE,
and many common DSP serial interfaces.
评论(0)
发评论
下载排行榜
