REF194,pdf datasheet (Low Drop
消耗积分:3 | 格式:rar | 大小:551 | 2009-10-23
h1654155275.0032
分享资料个
The REF19x series precision band gap voltage references use a patented temperature drift curvature correction circuit and laser trimming of highly stable, thin-film resistors to achieve a very low temperature coefficient and high initial accuracy.
The REF19x series is made up of micropower, low dropout voltage (LDV) devices, providing stable output voltage from supplies as low as 100 mV above the output voltage and consuming less than 45 μA of supply current. In sleep mode, which is enabled by applying a low TTL or CMOS level to the SLEEP pin, the output is turned off and supply current is further reduced to less than 15 μA.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
