1. General description The TDA8922B is a high efficiency class-D audio power amplifier with very low dissipation. The typical output power is 2 × 50 W. The device is available in the HSOP24 power package and in the DBS23P through-hole power package. The amplifier operates over a wide supply voltage range from ±12.5 V to ±30 V and consumes a very low quiescent current. 2. Features n Zero dead time switching n Advanced current protection: output current limiting n Smooth start-up: no pop-noise due to DC offset n High efficiency n Operating supply voltage from ±12.5 V to ±30 V n Low quiescent current n Usable as a stereo Single-Ended (SE) amplifier or as a mono amplifier in Bridge-Tied Load (BTL) n Fixed gain of 30 dB in Single-Ended (SE) and 36 dB in Bridge-Tied Load (BTL) n High supply voltage ripple rejection n Internal switching frequency can be overruled by an external clock n Full short-circuit proof across load and to supply lines n Thermally protected. 3. Applications n Television sets n Home-sound sets n Multimedia systems n All mains fed audio systems n Car audio (boosters).
