ADG1608/ADG1609,pdf datasheet
消耗积分:3 | 格式:rar | 大小:554 | 2009-10-30
分享资料个
The ADG1608/ADG1609 are monolithic CMOS analog multip-lexers comprising eight single channels and four differential channels, respectively. The ADG1608 switches one of eight inputs to a common output, as determined by the 3-bit binary address lines, A0, A1, and A2. The ADG1609 switches one of four differential inputs to a common differential output, as determined by the 2-bit binary address lines, A0 and A1. An EN input on both devices is used to enable or disable the device. When disabled, all channels are switched off.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
