ADG526A/ADG527A,pdf datasheet
消耗积分:3 | 格式:rar | 大小:195 | 2009-10-30
吴湛
分享资料个
The ADG526A and ADG527A are CMOS monolithic analog multiplexers with 16 single channels and dual 8 channels, respectively. On-chip latches facilitate microprocessor interfacing.
The ADG526A switches one of 16 inputs to a common output, depending on the state of four binary addresses and an enable input. The ADG527A switches one of eight differential inputs to a common differential output, depending on the state of three binary addresses and an enable input. Both devices have TTL and 5 V CMOS logic-compatible digital inputs.
评论(0)
发评论
下载排行榜
