Features True dual-ported memory cells that allow simultaneous access of the same memory location Six flow through/pipelined devices: ❐ 16K × 16 / 18 organization (CY7C09269V/369V) ❐ 32K × 16 organization (CY7C09279V) ❐ 64K × 16 / 18 organization (CY7C09289V/389V) Three modes: Flow through Pipelined Burst Pipelined output mode on both ports allows fast 100 MHz operation 0.35 micron CMOS for optimum speed and power High speed clock to data access: 7.5[1], 9, 12 ns (max) 3.3 V low operating power:
❐ Active = 115 mA (typical) ❐ Standby = 10 A (typical) ■ Fully synchronous interface for easier operation ■ Burst counters increment addresses internally: ❐ Shorten cycle times ❐ Minimize bus noise ❐ Supported in flow through and pipelined modes ■ Dual chip enables easy depth expansion ■ Upper and lower byte controls for bus matching ■ Automatic power down ■ Commercial and industrial temperature ranges ■ Pb-free 100-pin TQFP package available Functional Description For a complete list of related documentation, click here.
