LMZ12002 电源模块 可调哦
消耗积分:0 | 格式:rar | 大小:2.19 MB | 2017-10-18
分享资料个
  The LMZ12002 SIMPLE SWITCHER® power module APPLICATIONS is an easy-to-use step-down DC-DC solution capable
  • Point of Load Conversions from 5V and 12V of driving up to 2A load with exceptional power
  Input Rail conversion efficiency, line and load regulation, and
  output accuracy. The LMZ12002 is available in an
  • Time Critical Projects innovative package that enhances thermal
  • Space Constrained High Thermal Requirement performance and allows for hand or machine
  Applications soldering.
  • Negative Output Voltage Applications The LMZ12002 can accept an input voltage rail
  (See AN-2027) between 4.5V and 20V and deliver an adjustable and
  highly accurate output voltage as low as 0.8V. The
  LMZ12002 only requires three external resistors and
  four external capacitors to complete the power
  solution. The LMZ12002 is a reliable and robust
  design with the following protection features: thermal
  shutdown, input under-voltage lockout, output overvoltage protection, short-circuit protection, output
  current limit, and allows startup into a pre-biased
  output. A single resistor adjusts the switching
  frequency up to 1 MHz
LMZ12002 电源模块 可调哦
评论(0)
发评论
下载排行榜
