DAC716 pdf datasheet(16位数模转换器芯
消耗积分:3 | 格式:rar | 大小:666 | 2008-07-31
王飞云
分享资料个
The DAC716 is a complete monolithic D/A converter
including a +10V temperature compensated voltage
reference, current-to-voltage amplifier, a high-speed
synchronous serial interface, a serial output which
allows cascading multiple converters, and an asynchronous
clear function which immediately sets the
output voltage to zero.
The output voltage range is 0 to +10V while operating
from ±12V to ±15V supplies, and the gain and bipolar
offset adjustments are designed so that they can be set
via external potentiometers or external D/A converters.
The output amplifier is protected against shortcircuiting
to ground.
The 16-pin DAC716 is available in a plastic 0.3" DIP
and a wide-body plastic SOIC package. The DAC716P,
U, PB, and UB are specified over the –40°C to +85°C
range while the DAC716UK and PK are specified
over the 0°C to +70°C range.
评论(0)
发评论
下载排行榜
