ISO7221A双通道数字隔离器数据手册
消耗积分:5 | 格式:rar | 大小:212 | 2010-03-11
分享资料个
The ISO7220 and ISO7221 are dual-channel digital isolators. To facilitate PCB layout, the channels are orientedin the same direction in the ISO7220 and in opposite directions in the ISO7221. These devices have a logic inputand output buffer separated by TI’s silicon-dioxide (SiO2) isolation barrier, providing galvanic isolation of up to4000 V. Used in conjunction with isolated power supplies, these devices block high voltage, isolate grounds, andprevent noise currents on a data bus or other circuits from entering the local ground and interfering with ordamaging sensitive circuitry.
评论(0)
发评论
下载排行榜
