AIC3643 datasheet,pdf(Built-in
消耗积分:3 | 格式:rar | 大小:294 | 2010-03-22
分享资料个
AIC3643 datasheet,pdf(Built-in OVP White LED Step-Up Converter)
AIC3643 is a current-mode pulse-widthmodulation
(PWM), step-up DC/DC converter
designed to drive white LEDs with a constant
current to provide backlight in hand-held devices.
Series connection of LEDs provides identical
LED currents resulting in uniform brightness.
This configuration eliminates the need of ballast
resistors. The built-in open load protection
prevents the damage resulting from an open
circuit condition. Also low 100mV feedback
voltage minimizes power loss in the current
setting resistor for better efficiency.
评论(0)
发评论
下载排行榜
