PS5100 pdf datasheet
消耗积分:3 | 格式:rar | 大小:555 | 2008-08-14
分享资料个
The PS5100 module is a complete Smart Battery
controller subsystem based on the Microchip PS501
battery manager with patented Accuron® technology.
The module is designed to operate in a battery pack
consisting of six (6) to twelve (12) series connected
Ni-based cells. The module consists of the Microchip
PS501 battery manager IC with a four LED SOC
display and an optional connection for an external
thermistor.
1.1 Quick Start – Pack Assembly
Follow these directions to assemble a pack with the
PS5100 module.
• Use standard precautions when handling static
sensitive devices.
• Modules should be connected to battery cells in
the order indicated below to insure proper start-up
and operation. Wires should be attached to the
modules first and then connected to the battery
cells as instructed.
• The connection sequence is critical to successful
use of the PS501 family of CMOS ASICs. The
pack positive should be securely connected to the
module first, followed by pack negative.
评论(0)
发评论
下载排行榜
